2017 Findlay buy sell trade
Shirehorse
26
Mantua, OH
I have a NOS HUPP/Benmar 20k multifuel fired heater for sale, with control box. Make offer!
Slave cable adapters (2 pin to 1 pin NATO). 15 Bucks each.
Take off M939 Air brake spiders- make offer
5 ton front suspension- no u bolts, 150 bucks
5 ton steering box (new style) with drag link. 150 bucks.
5 ton wheel bearings inner and outer, used serviceable- 50 bucks/set (2 available).
Random axle parts, just ask!
minigunmike
Defiance Ohio
Hey guys, looking for some m35 parts. We had a fire in December and lost the cargo cover and the front flap along with the rope. Anyone want to get rid of some? Preferably green or tri camo.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I have a virtually new tan one for 200. Its dirty and the super rope needs replaced. Just an option if you can't find what you want.
MWMULES
351
DESOTO, KANSAS
Not your color but I have arctic NOS white cargo covers for $200 with good super rope. If anybody wants one let me know and it will go on the trailer.
I have two bolster/1061 16.5 disc wheels with crappy bias HMMWV tires on them that will lower your M105 $75 for the set. Gimp takes the wheels
Also found a couple HMMWV radio shelves $25 ea, MAXJEEP takes two
MWMULES
351
DESOTO, KANSAS
Not to derail just a quick sidebar, is painting a cover fairly easy?
Adding brown and black splotches to a green one seems to work well but trying to change color of a sand or white not so good. They start out ok, but the first hour trip at 50 MPH changes it and gives it the "stone washed" denim look!2cents
I have a couple New NOS 20' sand colored USMC 7 ton cargo covers that are great for civi goose necks $300 as shown on stonepickers rig with good super rope
Still have a few MRAP east coast mirrors with arm and hardware, $25 a pair
HMMWV radio rack shelves $25
Still looking for a MICLIC dummy linear charge linear charge.jpeand one MGPTS tent bow mgptsarch.jpg
gottaluvit
Shoot, I think white would be sweet looking. Not so common.
Bringing:
New complete, in box, 5-ton/Deuce left camo doors (only three left). Window, crank, handle,hinges. $190/ea. Edit: one left
New complete in box green M939 mufflers. $95/ea.
NOS M101 tri-color camo covers, green inside $250/ea.
Baldwin oil (B7700 High Efficiency) and fuel (BF7632 High Efficiency) filter combos for FMTV/LMTV $15/set or $10/ea. if bought individually.
Cat 1R-1807 oil filters that also fit FMTV/LMTV. $20/ea.
HET fuel water seperators (white canister with gasket only, no clear base) These are too tall for LMTVs. $20/ea.
NOS 18" wiper blades with hole at center (MRAP) which can be cut down for M939 series (which is on my truck) and others $10/set
Haldex DQ6050 desiccant cartridge kits for PURest MRAP air dryers (upgrade so many of us have made for our M939s, thanks to suprman), with gasket, catridge, bolts, lube $75/ea.
NOS 101" x 21" rubber splash guards (same thickness as LMTV splash guards) rolled up. These can be used to make your own length or anything else your heart desires. $25/ea.
Napa Gold 9677 $15/ea. (Quoted $225 from Napa)
Napa Gold 9557 $10/ea.
Napa Gold 7740XE or unmarked brand 5HA614 dual 6" trans filter kit with gaskets and drain plug seal for 3000/4000 series Allison transmissions (not LMTV as they are 4").
Does fit HEMTT $45/kit
New no box Spicer u-joints for MRAP and others
nsn: 2520-01-218-6498 $100/ea.
New OD green flat west coast mirror heads $10/ea.
NOS M113A2 radiator grill winterization covers with three velcro vents to adjust temperature. These can be repurposed with some imagination. $20/ea.
New Flywheel flexplate for Cat 3176 to Allison HD B500 T400 4000RDS transmissions. $100
2 3/4" stainless steel exhaust rain cap/flappers. $15/ea.
New Spicer M939 series column steering (propeller) shaft w/ u-joints (no bolts). $100
Horton fan clutch S advantage service super kit. $250
New Fleetguard power steering hydraulic reservoir filter (Baldwin P528) assembly with dipstick. Cummins no. A029M252, Oshkosh no. 3829585, Fleetguard no. A029J816. These are black, shiny, and large. Probably hold about a gallon of fluid. $25/ea.
New hmmwv wheel kit priced like it is steel and not gold, unlike ebay sellers have them now. $75
Other miscellaneous items like one set of M939 brake shoes, mirror with brackets for M915/916 (pretty sure, may be for HET?; check with me if interested and I can dig up the nsn), hmmwv seat base, and more. I have more loaded and will try to list it all within a few days. Always at a great deal. I have no use to collect dust. Sorry but the Chevy front fender is no longer for sale. I think I hear my CUCV rusting from in the house.
Wanting:
M939 steering wheel
M939 fenders (both sides, cab and hood mounted halves)
M1082 or LMTV anti sway bar tapered bushings. I need all four.
ida34
36
Dexter, MI
Need a driver's side small lower M939 fender. The small one that stays in place when the hood is raised.
rickf
2,224
Pemberton, N.J.
Read your own signature, That pertains to your back also. Take it from someone who has had 70 some injections and just had my second major surgery.
