bones1
- 4
- 18
- Southern Maryland
Anyone run super single's on the front only and if so how does it steer and look?. Any pictures?.
I'm sticking with the factory duals on the front of mine...............?
What thought?. Are we supposed to think before we post?.What is the thought process behind this(op)?
I was wondering if anyone has super singled the front only before and I see that someone prior to me has thought of this. Sure makes 'em look better.
I have thought about the possibility of putting a wider tire on the front. I like the look of the duals in the rear but would like a more aggressive/wider tire in the front. Sort of the look some of the concrete trucks have. I do understand that the tire diameters have to be the same in order for there not to be any problems if the front axel is engaged. Possibly using a re-centered HEMMTT rim???? But then what (if any) tires would be the same diameter/height as 9x20?
