tm america
- 23
- 38
- merrillville in
Size is one of the biggest factors in mud .Taller means more ground clearence and a bigger contact patch. Wider tires make a bigger contact patch to but do nothing for ground clearence.Taller wider tires are best for mud.airing down helps any tire.Everyone talks about how good ndts do aired down but 46s do the same stuff not aired down..If you aired down the 46s they leave the ndts stuck in a hole behind them
I have never seen ndts go trough a hole that 46s got stuck in but i have seen 46s go places ndts got stuck.If you are bobbing it i would go with the 14.00s the extra ground clearence will help you more ..46s and 48s have pretty much the same contact patch size so go with the one with more ground clearence
