- 10,349
- 94
- 48
- Meadows of Dan, Virginia
I agree with the fuel problem. Experienced something similar with my 018 and finally, after cleaning the carb several times, replaced the fuel pump.
Now, I had other problems too, like low compression, which made starting a little difficult. When everything was running well, the generator head failed...found sand and gravel inside the generator and figured that's what caused the failure...
