4Ao32 Standard engine powered genset CARBURATOR rebuild kit source
Jericho
68
Landaff NH
The 4A032 and a couple of other standard engines use the same carb, a zenith 13260 , it was coded XB3 so it was non accountable and throw away hence no repair . They seemed to have dried up and the last two I bought, ran no better then the ones I had, Dried up and perished seals and the ever present FLOAT to large , sticking problem. Found a probable source for a complete rebuild kit, around $40.00 and a BRASS float about $40.00 from the Carb Doctor on the internet, looks quality , all new brass works, will let you know!
Guyfang
22,097
Burgkunstadt, Germany
Jericho,
Good work!
Yeah, the SMR code was PAOZZ, toss away. Everyone used to keep a drawer full of them. If this turns out to be a good rebuild kit, that should help lots of folks. Thanks!
I heard this float could be modified to work in the 1A08 engine and some others.
https://www.amazon.com/gp/product/B0018TWJJ2/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I ordered one and its brass color, looks good and when I have an extra moment will see if it does
work or can easily be made to work. I have a number of these engines, 1A08 and 2A016, and typically
run into a float problem......or a sinking problem actually......
thanks for sharing!
Jericho
68
Landaff NH
hope it helps! , got three gensets running those carbs now, well not running actually, Will report when I get the kit installed Thanks fellas.
OK here are some pics comparing the inexpensive float I purchased off Amazon for $6 with a factory float.
Engine is a 1977 1A08 built by Chrysler (Mother MoPar)
Carb is likely a replacement and in nice shape, the float looks nice.
This is the engine that came off the air compressor I mounted the Predator engine onto in a different thread.
Note the crack in the intake manifold common in this application.
Comparing the two floats you will note it is NOT a drop in replacement.
But it does physically fit and my cohort and I are going to see if we can
modify it to work properly.
Thoughts or input welcome!
Jericho
68
Landaff NH
if the float ID and OD are the same and the bracket is different , Just solder the right one on, from the old one, Iam getting past the point of fab ing everything , Seems everything cost $100.oo lately, so if its less than 100 gramolees I just buy the right one, I don't have time to do everything anymore
Roger!
New bracket soldered on Sir!~
Need to try it now......see if it still floats.....
:razz:
Jericho
68
Landaff NH
Used to buy a lot from Saturn , good guys, BUT last two I bought were no better than the ones I had, except shiney, They were 70s vintage. Floats stuck within a hour of operation , seals were shrunk and flat ,Just age, Messaged them a few times with no reply and they don't list them for sale any more.
Guyfang
22,097
Ft. Riley is the reason I retired. After 19 years in the army, always doing what I was told to do, going where I was told to go, I came down on orders for Riley. I called my branch manager, to try and work out something else. I wanted Ft. Lewis, or Ft. Bliss, IF I had to go. I much rather wanted to stay here in Germany. My manager did not want to work out a deal, so I put in retirement papers. I might even have gone there, but when he said I would be there at least 5 years, that was the straw that broke the camel's back. I knew it was a stupid move then, and haven't changed my mind since. But I have been called hard headed before. I have a cousin that lives someplace around there. Works for a company that rents out equipment.
Jericho
68
Landaff NH
Bad news I am afraid , Finally got the kit for the carb, NO DICE , although it was touted as a direct replacement , its not Even the same carb parts, Will keep looking, BUT the float fits the Studebaker twin cylinder genset engine! am wondering if they have their applications mixed up
rustystud
2,388
Woodinville, Washington
To bad you didn't get Ft Lewis Guy ! That is just down the road about 60 miles from me.
rustystud
2,388
At least you tried. That is more then most can say. That makes you a "sheepdog" and not a "sheeple" . Sheeple just follow, the sheepdogs get things done.
