CUCVlooseNUT
- 0
- 0
- Clarks Summit, PA
Wow, now that might be a bit excessive to pull behind a pickup...![]()
I was 22,800# here. I took it real easy. When I got on it a bit, she felt like she was threateneing to throw parts on the street.
I broke a 1410 series Dana 80 pinion yoke towing a crewcab Super Duty through rough terrain uphill. Driveshaft took out the fuel tnak on it's way out. Low speed 4lo, didn't get the clutch in quick enough when the towed veh ot hung up. If you play with fire, you're gonna get burned.
My Dodge is a little over 400hp.
Deuce = low power, high weight. Dodge = high power, low weight put them together and I'm pretty sure you get BOOM!
Not to say you shouldn't do it or I wouldn't but you gotta be careful.
As far as your swap, It sounds like great Idea. Personally since it is a duce, I'd be looking for a medium duty Fuller 9 speed for behind that Cummins. Not the huge tractor trailer trans, but the smaller version that was found in Ford L-8000's and other medium duty trucks..
There's lots of helpful people, advice & tips, parts for sale, etc... over at http://www.Competitiondiesel.com that may help you with your swap.
