5 ton gears
gunit
indianapolis, in
i got 6.44 gears with 16.00x20's, would like to gear it down more. whats available. when my speedo is at 55 im at about 70. to fast for 22k#... acceleration? if my speedo went to 550 mpg would i be doing 700 mph or more. :driver: bet that would leave a crease in your seat cushion
paradeduty
Chelsea, Michigan, U.S.A.
hey gunit -
not an expert, but as far as I know - the only swaps are for the diff gears out of a 5-ton Bridge Truck. I think at least the original series 5-tons (M54, etc.) had higher gears for the 14:00-20 NDCC's.
there might be some gears avail nowdays with all of the axles that were used for the monster trucks and stuff but that is out of my field.
good luck, Dave
SixSpeed
Banned
1,107
Tampa, Florida
I haven't decided if we are talking about speedo gears or axle gears. Seems like there is a little of both in this thread.
If we are talking about speedo gears, who makes the speedo in the 5-ton. Do they use gear drives?
wehring
25
Angleton, TX
low
10.25:1 gears were issued in a few 5 ton variants. Look around Fl. The mud boggers love these with the 66" tires.
Justin Wehring
979 997 3112
355
11
New Enterprise Pa
There are alot of other ratios from the civilian world of truck that used the rockwell toploader that will work. I have 2 sets of axles with 5.81 ratio gears that will bolt right into the 5 ton so they are available.
tonka tester
N.E. Il
i need some in a 8-9 to 1 range:deadhorse: what kind of civilian trucks do i look for? old mixer trucks? crane trucks? or maybe i need some planets
