5 ton wrecker bed
tobyS
840
IN
Okay got it, no power beyond for that to be the interconnect line. It appears to come from the winch valve (A or B port) which could be pressure or return (depending on power running it in or out). My mistake...I thought this was a modified system that was only using one pump.
Please straighten me out as to what the (pictured) line is for. I don't understand this;
" it's a return for the second set of pto that would of been on the truck, and the big Fred for the main pump has a second port on it for the suction side of the second pump"
Heavywrecker
Onalaska wi
Little line is a return for the second hydraulic system, the big suction hose that goes to the main pump has a goofy fitting with a second outlet for a second pump to suck from under the hydraulic swivel
tobyS
840
IN
I'll stop interrupting this thread with my confusion about the purpose of this line. As a suction line, it appears way too small.
Heavywrecker
Onalaska wi
The fitting next to the pump goes on the big port of the pump and connects the auction port of the main pump to the huge hose from the swivel, if you look closely the fitting has a really. If port on one side, that is the suction from the swivel that goes to the tank, the other end of that fitting has a smaller jic connection, that is for the second pto pump suction from the tank
tobyS
840
IN
That smaller one is the return lol
So the return to tank from system 1 is plumbed to the suction of system 2 by this line. If system 2 is not operated, the flow would go backwards into that pumps suction line, pressurizing it (some). Of course it bypasses any filters this way.
Heavywrecker
Onalaska wi
It's a Hendy, bought it from a school that was getting new equipment, also have a big Bridgeport mill for playing with this stuff, the lathe was made in the late 40's I believe it says on it, something to do with military war production
Csm Davis
406
Hattiesburg, Mississippi
If the Bridge port has that tag you need to look real close at all the tolerances that is why it was tagged they were built really fast and not perfect to help the war effort.
Sent from my SM-G930V using Tapatalk
Another Ahab
4,948
Alexandria, VA
That's interesting to know.
I finished up my enlistment with reserve time here in the D.C. area, and our battalion would regularly drill over at Ft. Belvoir in Fairfax VA (it's an Army Engineering base but us Seabees had our own little corner of it).
We had a machine shop there in our "compound" just loaded with all of that heavy cast-iron pre-war (WWII) equipment. It was like metal-working heaven to visit that shop. :jumpin::drool::drool::drool:
Csm Davis
406
Not pre or post war but during WWII they relaxed the tolerances so they could be built faster.
