So I heard you can run a 50/50 mix if E85 and used motor oil.
Should a guy filter the oil first????
Do I have to worry about anything???
It will be exclusively Harley-Davidson motor oil, with a bit of tranny and primary fluids mixed in. Typically the oil is pretty clean when they take it out....usually at the 2,500 mile mark...if this makes a difference. For those not familiar with Harleys....the only thing different is that they do put a bit of gas in the oil over time.
