50 A outlets on generator
bones1
Southern Maryland
Mep-003A. What type/brand outlet and location did you use to mount a 50A outlet on the generator.I would like to use a plug in cord arrangement to the house.
Any pics would be great.
bones1
Southern Maryland
That is perfect, thanks. Is that generator mounted in the back of a Deuce?. I was thinking about doing that before I got one on a trailer. Still thinking about it.
steelandcanvas
85
Southwestern Idaho
No it's mounted in my M105A2. It was on a M116A3, but that looked pretty sad behind the Deuce. Let me know if you need part numbers for the plugs and outlet. You may not be able to find them at Blows or Home Dumpo, more likely a electric wholesale house.
bones1
Southern Maryland
Yeah, my deuce has MRAP wheels and tires on it and the little M116A3 trailer I have wouldn't even work height wise. Would look really dumb. Thanks for the help.
bones1
Southern Maryland
Part #s would be good if not too much trouble. Did you just run #6 wire from the gen bugs to the new plug? You are using 6/3 wire I see. I am using 6/4 so I may need different plugs anyway.
rustystud
2,742
Woodinville, Washington
4,693
I recently added a 50a civilian outlet to a distribution box I have. I tied it into the breakers of the output lead. I'll try to take some pics of it tomorrow.
Isaac-1
50
SW, Louisiana
Looks almost identical to my distribution box setup, except mine uses a pigtail to connect to output lugs, and the distribution box is not in a crash frame, (mine is a Coleman Extreme model 1970 which uses common straight blade outlets instead of the more common industrial twist locks). I also swapped out the L6-30 240V only 30 amp outlet for a 120/240V 30 amp L14-30 outlet (along with the appropriate neutral jumper) commonly used on many portable generators, inlet boxes, etc.
steelandcanvas
85
Southwestern Idaho
Very nice set-up you have there Steelandcanvas ! I would really like the manufacture and part number of that outlet on top of the generator. I have never seen one at any normal hardware store before.
Part #'s are as follows:
Plug-CS6365C
Inlet-CS6375C
Connector-CS6364C
Receptacle-CS6369C
This "CS" series is not cheap, but is what I chose for flexibility of wiring schemes. I believe the brand is Hubble. Your local electrical supply house is your best bet to find them in stock. Amazon and eBay had some fairly decent prices, so shop around.
DieselAddict
1,902
Efland, NC
That is the same connector style I used. I like them.
I used the Reliance LC550 series for the cord and the CS6369 recepticle.
steelandcanvas
85
Southwestern Idaho
I liked them when I worked construction, relatively bullet-proof casing and a very tight, secure connection. I had no idea so many of us preferred them...I must be in good company then. ;)
rosco
Delta Junction, Alaska
I did something similar.DSCN4494.jpgDSCN4483.jpgDSCN4484.jpgDSCN4491.jpgThere is a short 50 amp pig tail hard wired, that plugs into the distribution box, (all plugs are on breakers). Or it can be extended to go straight into the shop to power the house & shop, with load shedding. With the distribution box, I can plug into about anything, any where. It will probably be the neighbor, to keep him from freezing up @ -50. The tarp can be adjusted to keep it warm, so it will be easy to use, as its not convenient to do wiring at extreme temperatures.
m16ty
211
Dickson,TN
The anderson ones in 50amp(sb50) are under $10 if anyone is looking for a cheaper option..
Are those good for high voltage? The reason I ask is because I've only seen them used on low voltage connections, usually on electric forklifts, jumper cables, winches, and such.
They also don't seem very secure as far as somebody sticking their finger into a unplugged end.
