55mph detonation post mortum. . .
tm america
24
merrillville in
nice job looks like that engine has alot of new parts like the intake and turbo .i wonder if it was a non turbo engine that someone put a turbo on:roll:
FMJ
37
Las Cruces, NM
It's an 1988 engine, I took a picture of the data plate. Got a couple of questions, does the PTO have to come off?, or will it come out as it did in the non-winch truck? I've only swapped motors on non winch trucks. . .
Check out the smashed air lines. . .
few more pics
tm america
24
merrillville in
i would think you could get it out with the pto on there just gonna need to twist it a little to the side and probable take the air cleaner off the fire wall.wow what happened to the air lines and driveshaft
FMJ
37
Las Cruces, NM
Well, the connecting rod probably smashed the airlines and winch drive shaft. . . :-x
Lifting the motor now, more pics in a bit.
1,185
More pics!
1,822
You can wiggle it out and in with the PTO on it. Hardest part is always the juggle to get the pan past the front crossmember (unless you have the removable one). I always like looking at your pics Ed. Never know what you will see in the background. (Dually beds etc)
1,822
My SOP is to pull the winch. I can see where if you left it in place you would need to remove it! Coming along nicely Ed.
tx399999
Tulsa, Oklahoma
When I pulled my transmission I was able to drop it onto a furniture dolly with the PTO on top and it slid right out from the passenger side between the fender and tire.
FMJ
37
Las Cruces, NM
Ok, dead motor is clear, and a mess is on the shop floor. . .
Doesn't look like today will be the day. . . that winch is a PITA to get a motor out over it. . . especially by yourself :razz:
tm america
24
merrillville in
it.s funny the crank doesnt even look hurt .looks like the rod always breaks off the pin side :roll:were there any signs of trouble or did it let go all at once
