5ton speedometer adapter on Deuce
cattlerepairman
3,480
NORTH (Canada)
I ordered a 5 ton speedometer adapter from a vendor to compensate for my taller tires. Turns out, the two ends (speedometer cable and connection to the transfer case) on my deuce are "male" (male cable ends) , whereas the 5 ton part has a male and a female end.
I thought, ok, maybe I can swap parts around, but only managed to disassemble (and re-assemble!) half of the 5 ton adapter.
Any hints or ideas?
mikew
edmond, ok
Typically the transfer case end is "female"....
Try gently pulling the "male" drive pin out of the transfer case, it should come out. Normally it stays in the 90 degree adapter.
wdbtchr
St. Louis, MO
I'm not sure which is male or female, but if the 5 ton will fit the transfer case maybe use the 5 ton speedometer cable? I've had the adapter off my 5 tons but I can't remember which was which(old timer's diease).:roll:
jwaller
19
Columbia, SC
all the one's I have swapped have all been a direect swap. not sure if you have the wrong cable in there or what but it should just be a 5 min job.
cattlerepairman
3,480
NORTH (Canada)
I had tugged on it and it did not move. I will try again with more force.
