Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I was planning on doing a 5.9 Cummins swap. However, I would like to split the swap up to conserve funds. Anyway I can put a 47rh behind the 6.2. Any adapter plates available??
Try advance adapters, I have gotten stuff from them before. They make great products. Also- keep posting up your progress. I am interested in doing a cummins swap too.
Are you going to retain the 47rh for the cummins later on? Food for thought, I think there are different bellhousings on them between smallblock/ big block/v10/diesel. Be carefull when you buy one. Make shure it will work later on.
Yes, I plan on keeping the 47rh for later on. And thanks for that advice! I got some homework to do, but if it works out it will be easier than the 4l80e, right?
There are adapter plates out there, but you'll sink a fortune into adapting the SBC pattern to the V10/Diesel pattern of the 47RH. Just do it all at one time. You'll be thousands of dollars ahead.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
