6cta thermostat part number ?
seano11
104
Edmonton Canada
So my new m931a2 was getting hot on the highway so I figured it might need a new thermostat. Pulled everything apart and no thermostat was even there. Called cummins and orderd a new one using my engine serial number. Easy right ? Nope this ones way to big. Cummins swears it's the right one. The part number was 3913028 anyone have the proper part number for these trucks ?
madcroc1
deerfield beach, FL
I also believe I need one as well. But if you didn't have a thermostat in your engine, that is not your problem. I understand that without a thermostat your engine should be running as colds as possible. The thermostat only regulates water-flow to keep the engine running at 180 degrees or warmer. Basically it stops the water from flowing when engine temperature is below 170 degrees. When engine is above 180 then the thermostat is supposed to be fully open. If you dont have a thermostat, then that means that water flow is flowing at its maximum flow rate and your problem is most likely not the thermostat but possibly a water pump or clogged water system some where.
I'm not a mechanic but can anyone confirm my belief above ??
The reason for thermostats is to keep the engine running warm enough... If we never had a thermostat, the engine would run way too cold and cold means bad fuel economy and bad efficiency.
1,191
What part number is listed in the Technical Manual?
seano11
104
Edmonton Canada
I actually was given a thermostat for a 8.3 natural gas engine that's why it wouldn't fit. Have to love giving immigrants who can't speak English jobs...... Truck runs perfect now no more over heating
1,191
You could have avoided the poor customer service by giving them the part number(listed in the parts tm).
1,191
Ah, or is that aye...
glassk
Hampton, GA
A thermostat also restricts coolant flow so that it gives the radiator ample enough time to dissipate heat.
