- 10,822
- 7,372
- 113
- Camp Wood/LC, TX
Need some help from some of you with factory winches on your 800 series trucks. Trying to mount up a Garwood 20,000 to the front of Sirblissful's M820A2 and ran into a snag. First, looking at the inside the frame pics, do we need to drill out the frame rail and add more bolts where the gray primer spots are? Also, I was under the assumption that the M39 series and 800 series mounts are the same. The bracket in the second pic (from a M39 series truck) will not match up to the holes on the frame extensions we are trying to use. Anyone got a pair? They are too short to redrill.
Edit: Is it possible that the frame extension inserts we have are for a 900 series truck?
