Toolslinger
- 335
- 63
- PA
Well, it became frigid again, so I guess I was heading back to the 802a...
The plan was to roll it outside the garage to see if it would run.
Topped up the batteries.
Hooked up the batteries.
S10 to Normal
S17 out
S1 to Prime/Run
And... Nothing.
No fuel pump ticking
Malfunction Indicator Panel had 2 lights on:
Tried S1 to Start. Nothing as expected with fault lights on.
First thought was I had a bad crimp splice in those 2 circuits.
S1 back to Off
S17 In
Flipped the Battle short switch on
s17 Out
S1 to Prime/Run
Fuel pump came on.
Should have tried S1 to Start to see if it spun, but didn't think of it.
S1 Off
S17 In
S10 to Off.
Disconnect the batteries.
At that point I checked continuity through the 5 crimps that are associated with fuel level, fuel sender, and the LOP switch. They're all good.
Fuel tank is full, or right there. I had no fuel level, or sender issues prior to the burned wiring.
I had to walk away from it at that point as I was getting frustrated, and cold. I figured I can sit and try to make my way through the schematics sitting in the nice warm house, with a beer, and a much bigger monitor.
S10 to Normal
S17 out
S1 to Prime/Run
And... Nothing.
No Fuel
Low Oil Pressure
Pushed the Test/Reset. All lights came on. Release, still have the 2 fault lights.Tried S1 to Start. Nothing as expected with fault lights on.
S1 back to Off
S17 In
s17 Out
S1 to Prime/Run
Fuel pump came on.
S1 Off
S17 In
S10 to Off.
