m32825
- 173
- 43
- Central Florida
Got a coil top stove and have been using it to load my system. First time it has had anything other than convenience outlet exercise.
It was originally dropping out around 32A@240V. The AC interrupter light would go out and the engine would be back to running at no-load speed.
After cleaning and exercising S8 it sustained 48A@240V, everything the oven could give it, for half an hour (ran out of daylight).
Tracked down the oven's lower element wiring and hard-wired it "on" so I could run all both stove elements at the same time for more load. Was able to get 60A@240V, reading a little over 115% load. This ran for a little while (maybe a minute?), then the engine shut down and the "over voltage" light was on. Is this normal behavior for an overload situation? What was causing the interrupter drop out I saw initially?
-- Carl
-- Carl
