Bmxenbrett
- 30
- 18
- NY
Any one know the specs on the original pump? The airtex 8135 is showing 5.5-9psi and 35gph. There $30 on rock auto.
Looks like it.Does your unit have a Facet 40193 fuel pump?
I'll check that, thanks for the suggestion!When it goes to shut down, does the fuel cutoff solenoid extract to shut the unit down or does it just start to die without the fuel cutoff solenoid moving. If the fuel cutoff solenoid is not shutting the unit down, then you have a fuel delivery problem. I once had a unit that would shut down for no reason, then I found a small piece of cloth floating around in the fuel tank. The cloth would get sucked onto the dip tube and shut the unit down because it blocked the fuel delivery.
