813 tranny air valve
shootiniron
13
Escalante,Utah
I've got an 813A1 and the valve on top of the tranny is bypassing air.There are two valves and a port so to speak between them,its at the port that air is escaping.Is there a kit I can buy?Any advise is appreciated.Thanks!
73m819
314
gainesville, ga.
DAVE, what does eastern get for these kits, does it have all the O-rings including the O-rings for the connection between the two valves, do these kits cover both valves in one rebuild kit
shootiniron
13
Escalante,Utah
$100 for the kit from Eastern,or so the website says.As to how complete the kit is ,no clue but it does look small,not alot of stuff in it.I thought someone here was selling the x-fer case air valve kits or the tranny kits,cant remember.
73m819
314
gainesville, ga.
my valves work good, no leak from them, the leak is at the conection BETWEEN the two valves, just havent pulled them off and changed the O-rings, that is on my after rally to-do list. I would guess there is not much to the kits, mostly O-rings,
lsansone
sterling ct
from my experience, the air comming out of that port between the 2 valves is comming from the valves themselves. the center port is simply the exhaust port for either valve once it switches. at least that was the problem on my m817
best wishes
lou
M215
Spotsylvania, Virginia
I purchased my rebuild kit from Memphis Equipment, thought the kit was less than $100. The two large copper rings in the kit were a little small, ended up using the old ones instead.
Hope this is helpful
shootiniron
13
Escalante,Utah
Thanks for the tips.I'll prolly dissassemble the whole thing and thoroughly clean and re-install and hope for the best till I get another valve assy.
wbv
Alabama
This might be a little unethical but... I have the same problem on my M818 especially when the weather is cooler.
My solution (and it has worked so far) is to hold my finger over the exhaust until the pressure builds enough to close the valve.
I think I'll look for a way to lubricate this assembly before I buy a kit to rebuild.
wbv
pctrans
19
Bradenton, FL
Clark has the new valve for about $200. The ones I have taken apart, the rubber end that the plunger hits, were ate up.
