rizzo
- 9
- 38
- Port Huron, MI
has anyone pulled a civy semi trailer with an 818? what did you have to change? and how did you do it? I'm assuming lights are the only thing
pulls fine with the truck only. pull anything over 6klbs and it gets really slow in a hurry.rizzo said:how does it pull with the big tires?
I want to put 1600's on mine
everything works but the lights. and even they will work if you can hook them up. just not very long.TheBuggyman said:I don't know if I am off base here, but I believe that the root of the question is the compatibility of the military air/hydraulic braking system to the civilian full air braking system. Will the military system work with a civilian system? Does the emergency air serve the purpose of releasing the spring lock on a civi trailer and then the service side will apply the brakes as needed?
Roger that.DaveP said:everything works but the lights. and even they will work if you can hook them up. just not very long.TheBuggyman said:I don't know if I am off base here, but I believe that the root of the question is the compatibility of the military air/hydraulic braking system to the civilian full air braking system. Will the military system work with a civilian system? Does the emergency air serve the purpose of releasing the spring lock on a civi trailer and then the service side will apply the brakes as needed?
I'm pretty sure I have LED's on the trailer.DaveP said:everything works but the lights. and even they will work if you can hook them up. just not very long.TheBuggyman said:I don't know if I am off base here, but I believe that the root of the question is the compatibility of the military air/hydraulic braking system to the civilian full air braking system. Will the military system work with a civilian system? Does the emergency air serve the purpose of releasing the spring lock on a civi trailer and then the service side will apply the brakes as needed?
