matt2491
- 52
- 18
- Billerica, MA
Fuel filters are from 2020. I will pop them off and take a look.
Slime don't care how old the filters are. The dozer had a small cartridge filter and the slime was easy to see, and it had plugged it up enough to not start, etc. Would start on ether and then die. It's a place to look. Gelling will look cream colored, slime dark, maybe black..Fuel filters are from 2020. I will pop them off and take a look.
did you physically check to make sure the fuel pump is actually pumping fuel yet?Replaced the fuel filter today. Old one (2020) was about 3/4 full upon removal, but also rusty inside. I traced the supply line from the tank and I guess someone bypassed the fuel/water separator at some point cause I can't find it. The fuel goes straight from the tank to the pump then to this secondary filter and finally to the injectors.
I filled the new filter to the brim with fresh diesel before installing. I'm not sure how to properly prime the system so I just went ahead and cranked the engine over a bunch. No change in symptom.
they are also pretty easy to remove, disassemble and clean too. care must be taken on adjusting the fuel rack.....its been 40 years since Ive messed with them. I did it in the kitchen (clean stainless tables) of Moores Riverboat Restaurant years ago, for the owners old Lima crane dredge he used to keep the boat floating. It burned up years later.If you have corrosion in the fuel filters you may have stuck injectors. Pull a valve cover (the gaskets are reusable) and verify the injectors aren't stuck down. You can also exercise the fuel rack. Any stuck injectors won't change position.
If you do have stuck injectors all is not lost. I believe there is a procedure to use methanol to free up stuck injectors.
Yes that is correct pump fuel into that port.Wait... am I supposed to pump fuel IN through that port, not try to suck air out?
