Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
The MV's are designed for heavy duty off road use. The redundant filtration system is there to help for the extra effort put out by these trucks. I suppose when you're out in the field for extended periods of time (ie: war), dropping the pan is probably least likely to happen. So the incorporation of the spin on would at least be done on a "routine" basis...hopefully. In fact I just changed out my filters a few days ago.
How much oil dripped down your arm changing the pan filter? That pan weighed more than I thought it would.
What kind of gasket on the pan did you use? A cork one came with the filter kit I used (military) but the one that came off was a black one of what I would call "traditional" gasket material (thinner). The black gasket wasn't seeping at all but the cork one looks like it is starting to seep. I torqued to the upper end of the spec in the TMs. I hate leaks.
