- 3,219
- 384
- 83
- Tonopah, AZ
I check my fuel tanks with a 3/16" ( I think it is 3/16") painted steel rod.
On the A2's you have to go at a little bit of an angle.
You should be able to see where the strainer and the filler neck meet.Well I put a chain wrench on it, pulled as hard as I could. Won't budge. I tried giving it a little impact with a rubber mallet...won't budge. Put some heat around the filler neck...still won't budge. Used a cheater pipe on the chain wrench too.
My fuel gauge doesn't work, so it would be nice to physically measure the tank to see how much I've got, but this thing doesn't want to unscrew.
Definitely don't want you to break anything.
Are you looking at the pics posted on this thread? Post # 8Yeah, I'm not even exactly sure how/where the two come apart. Anyone have pictures to make this a little easier to figure out?
Thanks. I was definitely trying to take off the right part. It's not reverse thread, is it?Are you looking at the pics posted on this thread? Post # 8
f o !!!my fuel gauge works like a dream. Dont get me wrong, i still carry a full jerry can just in case. Its always better looking at fuel than looking for it.
Are you leaving room for fuel expansion?
Your fuel tank should have a tag welded on it that says it's capacity
The point was made by DH and not me but I would have asked the same question. The strainers were also put in there so with the nozzle filling the tank cuts off at the correct fill level - which should be 80% of its rated volume - thus leaving room for expansion.
I have the identical problem with commercial vehicles and drivers - first always trusting the gauge when its policy to LOOK IN THE TANK. If they run out of fuel by trusting the gauge - driver pays the breakdown costs to get him going again PLUS the cost of the fuel.
We have all done this and thus the second point - you "should" never fill to the neck of the tank - but I do it anyhow so do not listen to me its only a point.
Our On Site Fueling service never fills to the top of the neck.
You will run out of fuel before the gauge and fuel level get low enough because the pick up tube does not sit at the bottom of the tank - there is always some left (not like having ice cream around with kids - they lick the bottom of the bucket to get it all).
