aftermarket m35A2 heater blower motor
ODdave
36
lansing michigan
Ok after lots of searching, on this site and others i have found a replacment 24V blower motor for the m35A2 deuce and a half with the hot water heat. Allthough it is not exactly the same, the only mods i see that where needed are for the ground wire to be atached externaly (closest bolt) and the power wire to have your existing lead (bullet conector) atached. But the most important mod is the much needed quick coat of some beutiful Olive Drab paint. the motor is NAPA pn. 655-1320 . cost was $31.09 + tax. the only part i am slightly questioning is the fan depth, although it looks fine i wont know untill it is mounted. i will find out in a few days and post it.
Speddmon
Blind squirrel rehabiltator
36
Cambridge, Ohio
Awesome ODdave!!!!!!!! Keep us posted about the install and operation. I know there are several people who need replacement motors. Myself, mine still works but I have been searching off and on for a little while to have the numbers on hand just in case I need a new one.
jollyroger
Centennial, Colorado
Yep. Mine is starting to make the death humm. I have not wanted to throw down with the chemicals yet as I don't want to take the "magic" out of it until it gets bad. Thanks for the findings.
Lax
14
Upstate New York
Thanks for the work ODDave. I will be very interested in the RPM it turns. It would be great to be able to increase the blower/air output!
LiqTenEXp
NJ
Mine was DOA when I got the truck. I split the case open on it, flushed out all the gunk, lubed it, and put it back together. FYI, Proper alignment of the two rods that tighten the two parts together will insure the sleeve bearings are aligned properly to the motor shaft. After that it works like a champ.
Boatcarpenter
14
Marlborough, NH
ODdave,
Do you know if that replacement blower motor has proper bearings to operate with the blower shaft
operating in the vertical position as opposed to horizontally as it would in a normal heater installation in an A2??
I have my heater installed in the cab with the shaft vertical and now when I turn it on the blower
operates slowly and jumps up and down.
Thanks,
BC
ODdave
36
lansing michigan
ODdave,
Thanks,
BC
Not shure, all mine are mounted in the under hood location. All blower motors i have "disected" have had thrust washers. I would imagine it should be fine. Is it causing a problem?
Boatcarpenter
14
Marlborough, NH
ODdave,
Here is a question I asked Stumps in another thread. Explains what has happened.
"OK Stumps,
Here is a question for you. I mounted my heater in the cab and the blower motor is positioned so the blower shaft
is operating in a vertical position. Had some trouble so pulled the motor and fired it up in the vertical positiion. It works
but jumps up and down. When I operate it in the horizontal position, it runs fine. I suspect the end bearings are not
made for vertical operation. Having taken one apart, can you confirm this?
Thanks,
BC "
andybritt2002
Chesapeake, VA
I know this is a old thread, but I tried to buy online from napa. They cancelled my order and told me the item was on back order from the manufacturer. Is there any other sources for this blower motor?
AaronW
Napavine,WA USA
My local NAPA was able to locate 3 in stock in other states. $36.99 + $9 or $10 shipping. (655-1320) Carquest showed no match.
6x6TRex
Flint, MI
I work at NAPA so I'll run the # (BK 655-1320) tomorrow to check if its still available. Bought one a year ago and it worked great!
6x6junkie
p.a.
they are a good fit but after a year of good running i whould say i have 6-7 hours on my motor the bearing on the shaft went bad amature hit the field and no go . but still got another from napa thats a good part # in pa$ 42.50 cheaper than nos or new original
6x6TRex
Flint, MI
$34.99 plus shipping from the Napa I work at. 3 in other states, 6 in the warehouse in Indianapolis, and 28 in the warehouse in Salt Lake City as of 1:30 on 11/22/11.
