juddspaintballs
- 1
- 18
- Berkeley Springs, WV
I'm leaning toward purchasing a full hydraulic winch. Warn, MM, and Ramsey all make hydro winches in the 12-18k range for around $1300 brand new. I hope to find one used.
ok, but since you only need the winch and not the PTO or levers itselft, you should spend about $300 on this.not if you have to buy the winch first.
that's my plan.my next deuce will have a hyd winch front and back a gear hyd splliter.. so 2 winches ran of one pump drove by the pto
Exactly my point! A newbe by themself can get in big trouble real quick. It is real easy for those who have used this type equipment for years to forget about the learning curve they went through. As my dad would say: "the school of hard knocks"To me safety is job one... Its great to not have a shear pin but doent help get the truck unstuck if you are dead cuz the cable broke from over loading it....The biggest problem with the stock winch is the lack of knowledge ...It seems to me 99.9999% of problems with the stock winch are user error ..Everyone should read and carry a copy of the rigging and recovery manual before doing any winching..If you follow those guide lines you will almost never break a shear pin...there is a good reason the stock winch comes with so much cable they are made to be used with a snatch block or two....snatch blocks are needed for most pulls either to increase the capacity or to get the proper angle..No matter what winch you decide to use there are good and bad about it ...All you can do is make an informed decision based on your research..
i see this comment or similar often around here. i understand that these trucks can be had for dirt-cheap. but that doesn't mean that other equipment will be (or even should be) as relatively inexpensive. it's not logical to compare a piece of equipment from another industry to the cost of your surplussed MV.The 18000 lb EE winches I find on ebay cost more than my truck. ...
