Air bubbles. And hard starting
Floridianson
2,521
Interlachen Fl.
Yes the one you have with the red around it... It had some air bubbles coming from between it and the filter head so I tried to tighten it well the top part snapped off and then i tightend the bottom of it and no more bubbles from it. I was just wondering what its main purpose was and to say its now broke but not affecting anything ( that i know of ) Because I can put my hand/thumb over it and it has no psi/vac and nothing changes
That is your air bleed screw or where you would hook up pressure gage. You need to fix this fitting.
DEUCEBIGALOW
Seneca MO
Well I changed the filters and bled the system NO MORE AIR But i have to put the pedal on the floor and after 8 secs of cranking it will start... RUNS great after that...
DEUCEBIGALOW
Seneca MO
I went out just a min ago and tried starting it and it started without putting the pedal down it just took maybe 10 secs or so... the air filter is new.. ??
