- 330
- 3
- 0
- greenville sc
Does anybody know if a ½ drive 650 ft.lbs air impact wrench is strong enough to break the lug-nuts loose on a duce???
A 500 gallon air tank!!!!!!! I am guessing that is a typo?Depends upon the tool that put them on, my Snap On was not up to the task, it got 9 out of 12 loose on the rear axle. I had to go to a buddy's truck shop for the others, old Snappy would not touch any of the inner nuts. I have a large two cylinder compressor with a 500 gallon tank, it will maintain over 100 psi on an open line and shuts down at 130. Glen
Accourding to my math, that tank will hold 391.5 gallons. Maybe they're calling it a 400 gallon tank.Might be wrong, it is about 6 feet tall and 40" in diameter. Is that a 300 gallon tank? I know when I moved it, I had to leave the tailgate down on my M1008 as it was too long for the bed with compressor. Glen
Wouldnt be the first time someone tried to remove the drivers side without success.You never said if you were having problems, or just wanting to know.
If you are having a problem, just remember that there is NO lefty loosey, rightie tightie on the military lugs.
