Hello all. Just finishing the fluid changes on the 94 M1090. The voltage regulator tested bad and looks like the new one will be here tomorrow. Hit it with the pressure washer and it's interesting to think of where all this dirt and rocks come from.
The steering knuckles seem to take quite a bit of grease. Started showing on the lower, but still nothing on top. Same on driveline slip yokes. Figure I'm good to just keep going.
Martin from FMTV sales mentioned to make sure the drivelines had been updated since its a preproduction truck. Is there an identifier I should be looking for?
CTIS, 5 lights steady on. I'm hoping that with full voltage it will resolve the issue. Looked through the TM's and searched the forum and the goog and didn't find anything about five steady lights on. No action in the system. Is this a sign the controller is bad.
Air over hydraulic control. When turning the knobs, I can feel the detent between selection. The lower control knob doesn't seem to have detents, and doesn't turn to the right quite as far. I topped off the resivore. Cab functions, spare functions, but the suspension function doesn't work. I was figuring cycling it through might just be good. The TM's are mainly relying on pressure tests at various port's.
Do you guys have any info on what is typical for these systems, and if that lower knob should feel like the others?
Plug questions. Wondering what these are for. The one on the back of the cab? Roof Service light? Mine has the button on the dash
The one by the air box?
Thanks in advance.
Thanks in advance.
