Air warning buzzer won't stop in M932a1
rrrr
Missouri
Just unscrew the electrical connection on top of the unit its all on module. Be aware that you will have no warning for low air or if your parking brake is on.
On an all air brake truck be very carefull.
jw4x4
Dayton, Ohio
Is the buzzer supposed to be on anytime the parking brake is applied???? Mine buzzes until the parking brake is released.
1,188
MECHANICAL PARKING BRAKE CONTROL LEVER is pulled up to engage
parking brakes and down to disengage brakes. Knob on top of handle is turned
clockwise to increase parking brake tension and counterclockwise to decrease
parking brake tension. When parking brake lever is applied, it also trips a valve
to release air pressure from spring brakes. This engages spring brakes.
I'm guessing that is correct JW.​
nf6x
Feral Engineer
1,630
51
Riverside, CA, USA
The buzzer sounds for either low air or the parking brake being engaged. Two warning lamps above the steering wheel tel you which condition(s) the buzzer is calling your attention to. It is normal for the buzzer to sound until you have minimum air pressure and release the parking brake.
