Airhorn problem.
movcondude
11
Holstebro, Denmark
This drives me crazy - The horn on the Deuce dont work when operating the vehicle but after a standstill where some of the air has leaked out it works perfect again !?! I suspect its a defect in the air control valve... Anyone ???
dmetalmiki
2,036
London England
I'd say your correct. There isn't enough 'pull' on the solenoid to open against air pressure by the sounds of it. (scus'e the pun). I did see that happen once when someone wired in 24v. air horns and connected them across the first battery for 12 volts.
pjwest03
37
Vestal/NY
The solenoids can get weak and or sticky with age. I would also check the the 24V and ground at the horn. In my truck the wires were deteriorated where they were crimped into the pins. Also, I had to use some emery to clean the steering wheel nut under the horn button where the spring makes the ground contact. I also added some dielectric grease there while I was at it.
rmgill
14
Decatur, Ga
You might try squirting some air tool oil into the solenoid and operating it a bunch on the bench with a 12 volt battery.
