CUCV85
- 4
- 18
- central/ny
Sure sucks you have to buy new glow plugs is right.that sucks you had to buy new glow plugs. were the old ones fried?
That MEANS your system has a fault!
Glow plugs last for years when a system operates correctly.
I know with the military system having the resistors
there is a pain
for once you loose a Glow Plug they all eventually burn up and FAST.
Having a civilian setup or having done a resistors bypass
(basically removing 24 volts from going to the glow plugs)
if you had a wire not connected tightly on a glow plug
or having lost 1 or 2 glow plugs for say -
your other functioning glow plugs can actually work to start the truck
for quite some time.
Food for thought.
