AM General and Kaiser owners sought
rumplecat
215
North West Arkansas
David:
Have you hit up any of the state forestry auctions, they have dozens of trucks of all types, and they don't mind you spending all day looking at them at least not in the MO, KS, AR and OK regions I have been to. Just a thought.
James G.
Adamlee
Alexandria, VA
kaiser reg info
DDoyle said:
Adamlee - my eyesight is not the best, so I struggle to read the info on the data plate that you posted. However, and correct me if I did not read this correctly, it appears the VIN is 0325-28273, and the registration number 04B-76270. If that is correct, you truck was ordered on the same contract as bottleworks, was also built without winch, and left the assembly line early in 1970.
David Doyle
sorry, I went and looked and what I read on my plate was 04B-76970 with a VIN of 0525-28273.
hope this helps! also, the truck has a non-turbo M/F motor with 1969 date codes throughout; so I assume it's likely the original motor. I have also attached a pic of the inner driver's door which is stenciled 04B-76970.
123mack
11
Jemison, AL
I hav a M35A2 with serial number 012520206. The data plate reads M35A2 W/Winch. It came from the DRMO at Benning about 6 months before GL took over
DDoyle
80
West Tennessee
I just wanted to move this topic back to the top - I'm still working on making something meaningful from this data.
Any more VIN/serial/registration numbers appreciated.
Regards,
David Doyle
DDoyle
80
West Tennessee
RE: Born that year
OD Coyote, do you happen to know the Army registration number for your truck - aka Hood or USA number?
Thanks,
David
OD_Coyote
58
North Bend, WA
David, Sorry, but I do not have the registration number. When I repaint the truck I will make a point to get the registration number then, if possible.
Regards,
C. D. Hunter
DDoyle
80
West Tennessee
Yours is in a somewhat troublesome range of numbers that I'm having some trouble with - but you haven't been forgotten.
Best,
David
