Okie Dokie, so I am in Afghanistan right now. Over the course of this deployment I have been buying parts to build the 6.2 in my 86 M1009 (military blazer). As of right now, i have brand new glow plugs (the correct military ones), brand new GM-8 turbo, brand new 6.5 intake (complete), Brand new 6.5 marine injector tips to put on my 6.2 injectors, and a complete SM465 with hydro bell-housing. Right now I am planning on towing the truck to the exhaust shop after everything is on, and having them do the crossover, and complete 4" exhaust, probably going to use a duramax muffler, because I would like it to be fairly quiet. The only thing that I am kinda stumped on is whether or not I should go ahead and buy the DB2 IP, and 6.5 lines. Will using that pump, versus the one that is on my J code (i heard the military ones come turned up a little) make any real difference? Also, if I do go with that pump, will I loose the ability to run WMO in my truck? I know the military pumps supposedly have hardened parts in them so you can run all kinds of fuel in them, or something along those lines.... Anyways, I get home at the end of the month, and I just want to make sure I do this right the first time. let me know if there are any hangups you can foresee, and if there is anything you might suggest, thanks. Oh, in case anyone is worried about the axles not holding up to the torque of the engine after the build, i have rebuilt 3/4 ton axles at the house, with discs front and rear that I will be swapping in as well.
