richingalveston
- 121
- 63
- galveston/Texas
yes, there is a metal line that runs up the engine and over to the filter, another metal line leaves the filter and runs under the manifold to the center connection of the IP. If you look under the manifold you see where the injector lines come out of the IP. The center one is the input from the filter. It is hard to reach to check it, but find where that line meets the filter and check to see if fuel is getting to that point.
