Any ideas on getting the 1 3/16th nuts off body bushing bolt
Awesomeness
1,522
Orlando, FL
I was out of my go to kano kroil inthe orange cans to have to use the pb was all i had .I havent herd of the Freeall where do you get that at?
Free All is a premium penetrant, similar to Kroil. While it's an endless argument of which is the best, the premiums generally all work better than PB Blaster, and you're not going to get significantly different results from one premium over another. If you normally use Kroil, just stick with it... Free All isn't going to magically save the day.
chucky
19,298
TN .
Had to use a 40” 3/4 breaker bar to do that once. It helped to remove the bumper and had the wing that holds the headlight off. That was on my winch swap, so taking all that off was part of the gig.
Ah the smell of victory this morning with 6 ft yes 6 ft of heavy 2 in square tubing and 3/4 ratchet about 18 in of extention and some tarp straps to hold the the ratchet end up on the nut but it poped like a 22 rifle when they broke loose . On the drivers side i just loosend the 1/2 in nut on the infared light in drivers side bumper and twist the light over you can get the nut big washer and whats left of the bushing out coming straight down without droping bumper pass side u have plenty of room to change out. good luck to all on this task !
