Any interest in winch top plates?
Ridgerunner
Holland, Mi
Wish someone would make them for the 5ton winch. Both my top plate and plate on the back side are bent outward by quite a bit.
Are the 5-ton and Deuce winch top plates the same looking, just the 5-ton is dimensionally larger?
If so, I can do them also, at the same time. I'll just need accurate dimensions to make them for a 5-ton.
Ridgerunner
Holland, Mi
Anyone make the rear plate?
I can do the rear one also, but it would be soild, and not have the three square holes cut into it. I would serve the same purpose (maybe even stronger ?), but it would not be correct for a full on restoration.
If you really needed the square holes in the rear plate, I could Plasma cut them into it, but would prefer not to.
KsM715
142
St George Ks
I took a quik measurment today of the top plates on both the deuce and 5 ton. I belive the deuce was something about 4-3/4 wide and the 5ton is about 5" wide and longer then the deuce. But basically the same shallow u shaped channel.
I will get some more accurate measurments tomorrow.
deathrowdave
84
falmouth, ky
I had a sheet fab. shop make mine a year ago or so. Used a hole saw to drill holes in the back plate and cut between the drilled holes . Worked great , wish I could have purchased them for your asking price, cost me $ 40.00 each !!
Ridgerunner
Holland, Mi
Today so far I sheared up and formed, 12 winch top plates and 7 rear winch plates for Deuces. If anyone wants any of these right away, I can send them out on this coming Monday (Oct 10) without any mounting holes, if you want to put them in yourself.
or...
If your not in a hurry, I don't work Fridays, and that's the day that I do my own side stuff in my shop. So I'll make a layout transfer punch jig and finish machining the mounting holes then, and can send the plates out after that process.
Send me a PM if your interested in front or back winch plates, and with or without holes.
thanks
73m819
327
gainesville, ga.
This is what makes the USA so great, someone found a need and filled it, another SMALL BUSNESS is started
F18hornetM
10
Ocean City, Md
Looks nice, what gauge did you make them out of? I had a spare sheet of 10 ga when I made mine, but wasnt sure what thickness it was supposed to be.
