calvin3103
- 0
- 6
- ewa beach HI
I went to go pick up my M936A1 wrecker from the GL yard today, and did all fluid checks and jumped it cranked right up had a rough idle but smooth out, air was pumping good i checked the red glad hand and air came rushing out so i put on my glad hand airhose was airing up the tire then after a while there was no air coming out but had air on the gauges inside so i hit the brake release and pump the brakes then all the air went out and will not charge up its like the compressor just went out, unless there is a trick to this thought i was going to drive this babby out today only had a few hours to get it running before thay go home.
thanks.
thanks.
