Are Runflats worth trying to save???
Special T
21
Wetside/ WA
T, agree completely. The key is to not generate any more than necessary.
With heavy equipment tires manufactures produce a load, speed duration, inflation table so that you can operate with in specs. They don't do that for DOT rated tires, I'm guessing for liability reasons. All their tables are based off max air pressure for a DOT tire.
Some of you may remember the Ford explorer tire recall. All the tires that caused rollovers were in the hot SW of the country. The tires were no different than the replacements just had 28psi stamped on them instead of 32 or 35. (Can't remember which)
Sent from my SAMSUNG-SM-G930A using Tapatalk
someoldmoose
Lancaster, PA
Yes, Ford screwed the pooch on THAT one. Hence me always pushing the "chalk check". That's wut the tires actually NEED. NOT what makes them cushion people's tuchases the best. Good ride means too low. Proven it time and time again to my customers over the years.
