AS-3900A/VRC Antenna work with RT 524?
PowerstrokeNC
Greensboro, NC
Will this Singcars antenna work with my RT 524 radio? I looked up the specs and it said it covers the 30-88Mhz band but obviously has no switch in the base for changing the tuning.
Any thoughts? thanks
tennmogger
541
Greenback, TN
The AS-3900 is compatible with the RT524. The transmitter will be happy enough with the match, and the receiver will hear. The down side of these frequency-hopping antennas is that they are a compromise between no-tune wide-band coverage and antenna gain. Gain is about -6 db. In other words, divide the radio output power by four and that's what the antenna radiates, maybe.
And the AS-3900 will look good while eating your transmit power :)
SCSG-G4
PSVB 3003
3,320
Lexington, South Carolina
Thats funny! So maybe I will start with this one and look for the adjustable version for down the road....[thumbzup]
Don't wait too long, the 6704's are getting harder and harder to find! And you can only use the 524 on six meters as a HAM operator. There is a thread on modifying the 3900 for use with the CB frequencies. You might be able to do the same thing for 51 MHZ, so it becomes a six meter antenna without all the other coils to eat your output power. If you try it, take pictures and post a write-up for others to follow your lead!
PowerstrokeNC
Greensboro, NC
Thanks for all the input, is the whip the same on the As-3900 and the 6707? I have found a 6707 base with no whip so thought I could swap it if they are the same.
