I just bought a 802 that has been completely rebuilt, new engine and all accessories..RESET, in 2010.It has 27 hours on it. Looks new.. As soon as I got it, I filled the fluids, and it fired right up, but it died in under a minute of running.It ran smooth and perfectly for that time. I can get it to start again, but sometimes it runs on only one cylinder, coughs and stalls.. Never for more than 30 seconds or less.. Occasionally, it will start and run perfectly fine, but it duplicates the same malfunction. Definitely sounds like its running out of fuel..
I changed the fuel filter, and the secondary. Both fuel pumps are new..yet they don't seem to put out much..Tank is clean.. I even tried the auxiliary line, and no dice.. Same issue.. No lights fault lights Same problem in Battle mode. The fuel filter doesn't seem to be full when I loosen the drain on the bottom.. Not much fuel seems to come out of either of the the transfer pumps..Odd..
The man I bought it from swears it was perfect and running fine when he shipped it..Of course..I have no reason to doubt him.. Yet, it doesn't run I'm at a loss.. .. I'd appreciate your help.
Thanks, Rick
Thanks, Rick
