offroadexpeditions
- 1
- 0
- florida
Does anyone use anything else then straight diesel in this engine? Do you burn any mixture? Thanks
I have run a 3116 over 25000 miles with 50 percent used motor oil with no problems. I mix it with diesel and then filter it to 5 microns. The only thing is it smokes a little getting up to speed and starts hard when it is cold out. I can not tell the differnce in the heat of the summer. This is a ideal engine for a fuel mix becauce it does not have any electonics and uses a supply pump.Does anyone use anything else then straight diesel in this engine? Do you burn any mixture? Thanks
And you are talking about the M35A3's CAT3116 engine, right?I have run a 3116 over 25000 miles with 50 percent used motor oil with no problems. I mix it with diesel and then filter it to 5 microns. The only thing is it smokes a little getting up to speed and starts hard when it is cold out. I can not tell the differnce in the heat of the summer. This is a ideal engine for a fuel mix becauce it does not have any electonics and uses a supply pump.
since you are in FL, can you be a little more specific about 'cold out'?I have run a 3116 over 25000 miles with 50 percent used motor oil with no problems. I mix it with diesel and then filter it to 5 microns. The only thing is it smokes a little getting up to speed and starts hard when it is cold out. I can not tell the differnce in the heat of the summer. This is a ideal engine for a fuel mix becauce it does not have any electonics and uses a supply pump.
Below 70.since you are in FL, can you be a little more specific about 'cold out'?
Yes a m35a3 with a 3116 that I use as a dump truck.And you are talking about the M35A3's CAT3116 engine, right?
Below 40 not 40 below. Born in Vermont moved to Fl.since you are in FL, can you be a little more specific about 'cold out'?
Have you tried anything else than used motor oil?Yes a m35a3 with a 3116 that I use as a dump truck.
No I get used oil at our shop from trucks that we service regularly so I know what I am getting. I do not have a source for anything else.Have you tried anything else than used motor oil?
yes and it's spelled multi fuel. and no we are talking about the M35 A3 CAT engine that is not multifuel.Isn't it called a " multifeul" for a reason ?
