Chainbreaker
- 2,111
- 113
- Oregon
Very true, heat can damage most any component if too much is applied; however bare lead reed switches are cheap to replace. If the leads coming out are long enough there are ways to heat sink the leads near the component while focusing just enough heat on the extremity of the lead being soldered. To heatsink I sometimes use bare alligator clips and/or copper wire coiled tightly around a portion of the lead with ends sticking out into air (sometimes a tiny dab of thermal paste helps insure better heat transfer). The key to silver soldering is using the right flux and prepping the metal to not have any contaminants (finger oils, etc) as well as using a good quality micro torch. Not much to lose by trying unless one happens to own a capacitance spot welder or knows someone that has one as that would certainly be a better method of reattachment.I (strongly) suspect that the heat will damage the reed switch if you try to solder it. The wires are normally welded which transmits little heat to the part.
Although, an attempted repair may be moot if he does manage to source an affordable level switch assembly replacement.
