Stagg
- 0
- 16
- Kansas City, KS
I just got done replacing my axle vents with rubber lines. Next step is to check and repack bearing that have been washed out by 90w gear oil.
Anyway, I took some pictures along the way and the mod was "easy" to do if you are small enough to sit under the truck and wiggle in around the rear axles/braces.
Starting with the rears, I removed the old one way axle vents. (I found they stick shut beyond the rated 2psi) In their place I installed a 90 degree hose barb. Then I ran 3/8 in. hose from the barbs up towards the front. I ran the new hoses alone the brake lines with zip-ties. Figuring that those lines have to flex with the axles and truck and therefore represent the proper amount of slack. Had to use a tee to match the brake lines in the rear.
Then I did the same with the front axle: 90 degree barb, ran the hose along the brake line and along the frame.
Then I used a second barbed tee and connected the rear hose with the front. From that tee I followed the brake breather vent up the firewall.
Currently the new axle breather vent is just zip-tied to the brake vent, someday I would like to convert it over to copper line.... or continue it on up and into a snorkel
to go along with my fording goodies.
So here are the pictures see if you can figure out what I'm babbling about.
PS. I can't think of a problem with this type setup, but these trucks can sneak up on you with funny quirks. Is there anything I should watch out for? I assume (after a bit of researching) that little gear oil will be forced up those tubes. Right?
