Axel Vent Mod, 2.5 ton Rockwells
hklvette
Christiansburg, VA
It seems to be like it would be a trivial task after this setup is added to put in the low-pressure regular to make it a true fording setup. That's what I'd like to do with mine one of these days.
Stagg
Kansas City, KS
hkvette, That's what I'm thinking. Someday down the road, I'll add the full blown fording kit. For the moment I'm just tired of changing (and worrying) about repacking bearings.
However, I am noticing a trend of NOT putting 90 degree elbows in the lines. I'm tempted to change them now.
jesusgatos
on the road - in CA right now
Just fyi guys you do not want to run the 90's but straight up from the diff.
Oil vapor will pool in the line and harden, when that happens the air can not expand and your axle seals will fail.
Yup. I can vouch for that. Running the vent lines on long horizontal stretches, or allowing the vent lines to dip (where sludge can pool) will also cause problems. I'm going to plumb fittings into my fording kit that will allow me to blow-out the vent lines.
Stagg
Kansas City, KS
Does that gear oil really create a vapor? Either way I may reconsider, or just add a maintenance step where I blow the silly things out very now and then.
There is a lot of horizontal line running from the rears to the front/engine bay.
treeguy
Fort One Bay - Cape Cod, MA
Just a thought that has been lingering in the back of my mind. (nice set-up!) With the lengths of hose/tubing added to the axles and the gear cases, will they (tubing) build up condensation that will find its way back into the gear cases? While running the trucks there will be heat generated by the gear cases warming up the air inside of them, but because of the lengths of tubing, I would imagine that the tubing would remain cooler. That is why I'm wondering about condensation, due to the temp. differences and changes. What do you guys think? Am I way over thinking this?
