Dual Rear Wheel 14 bolt axles have a narrower housing.Is there any difference between the D60s width on the Dually version other than the reverse wheel adapter?
(remove the adapter and would it be the same axle as the 1008?)
Is there any difference between the 14bolt on the dually width wise? Is it narrower to add duals on each side?
QUOTE]
The drw and srw d60 front axles are identical except for the hub/rotor assembly.
imbobbbb is correct sorry Drjekl there is no dif in the dana60 srw or drw housings. they are the same the dif comes from the hubs pull the hubs and change to the other! the rear 14 bolt is another storySooo trueAsk yourself what you like most about your M1008, then move that over to the dodge. Might be easier.
I was refering to the rear axle. Edited to clarify. You will note he was also asking about 14 bolt axles. A Chevy 60 front is a Chevy 60 front with few exceptions.imbobbbb is correct sorry Drjekl there is no dif in the dana60 srw or drw housings. they are the same the dif comes from the hubs pull the hubs and change to the other! the rear 14 bolt is another story
