Back up camera Deuce
joeinaforest
11
Spencer, IN
Ok, all done except the paint...
[media]http://www.youtube.com/watch?v=DLNowxSjfnA[/media]
10" display off of ebay 80 bucks plus like 11 for shipping. Sub $100 for the entire install. Got the batteries for free from work...they are used, but will run the mirror for many many hours between charges. I charge with a little solar panel. Used Anderson Power Poles for easy disconnect/charging of the batteries.
I know, most of you will be like "why"??? WEll, because I'm a control freak and DESPISE not being able to see directly behind me. Now I can :)
Works at night with some infrared LED's around the edge of the camera...
J
ApopkaFL
Banned
596
Middlesboro KY
I plan to install them all around my truck. So I can see what is around me when I am backing up, changing lanes and so on. With the truck being on 53" tires and 8"; lift its tall. There is a company that sells a 7" display unit that you can use it to view 4 video cams at the same time.
Ripcord01
9
Waldorf ,Maryland
The back up cameras are nice to have. Good job,, I have one on my CiVi truck . You might be careful so you don't become like me and rely on the screen to much. I t is nice not having to stand up and twist your head around..
joeinaforest
11
Spencer, IN
Here is a link to the same seller I bought from: 10.2" Rearview mirror monitor + Water Proof Camera + TS | eBay
Takes a couple of weeks to get it.
I aimed it so that it just nicks the hitch. When I get a trailer life will be good!
And no, it does not record. Just use your phone to record po po interactions if you are worried.
If you would like a DVR to record, I'd recommend www.supercircuits.com never the cheapest, but always good. IIRC, you can get into a dvr for about $120 that records to an SD card.
I purchased this system for the display, not the camera....but since it was there I used it. I don't expect the camera to last for long, hopefully a few years...
Also, this unit will accept 2 cameras at the same time, so it would be very easy to add another, regular NTSC output.
The cheapo camera gets a little contrasty in bright sun and at dark...but I figured it was free, LOL. It also only has about a 50 degree view angle...I'd rather have like 100 degree wide angle. But, I still use my mirrors like normal, so not a problem, just gives a great view of the hitch and immediately down. I can see with my angle about 15' behind the truck.
1,806
Hmm, now I'm thinking. Works at night with little infra reds. I have at least one IR tank light. Wonder if that would be too much light?
