MatthewH
- 3
- 18
- Boyne City Mi
Pretty sure my starter took a crap, again, for a 4th time in my '09. Just wanted to run it by you guys to make sure I was correct.
Went out at lunch to move truck to load some stuff, hit the key to start, and nothing. I could hear the bendix engage the flexplate, but no cranking. Tried several times, with same results. This has happened before, but it has always "fixed" itself.
Reached under the dash, and checked the relay, was warm, along with the wires going to it. I grabbed a new one from the glove box and replaced it. Tried again, this time nothing, no cranking, no noise. Turned the key off, and pulled the keys from the ignition, reached under dash again and the starter began cranking. Pulled new relay, waited a minute, and put in the old relay. Tried again, this time with no results. Pulled relay and called buddy for a tow.
Plan on replacing the starter and doing a 12v conversion, since this is the 4th time i have had issues with the 24v system, especially the starter, but wanted to make sure it was the starter, not some other issue that has developed.
Thanks in advance, and sorry for the long post
MatthewH
MatthewH
