bad water pump?
doghead
4 Star General /Moderator
1,192
NY
Why do you ask?
Do you have issues?
Leaking is the most common issue.
Tow4
671
Orlando, FL
Dittos on leaking. I've only seen one that had a rusted off impeller. If it's over heating and there's not a puddle on the ground, it's something else.
Hasdrubal
Vancouver BC
If it is leaking. Verify that it is indeed coming from the weep hole at the bottom of the pump shaft, and not one of the lower pump bolts. They go through to the water jacket and require sealant.
