- 2,811
- 41
- 38
- Mt. Eden, KY
As mentioned, torque to the spec annotated in the tech manual. Hand tools may feel like it tight, 3/8" drive torque wrench is the charm, a little oil between the fitting and washer helps.I used all brand new washers and fittings and 3 out of the 6 were leaking. I'm thinking they might be a lower grade copper which would make them harder. Maybe I'll try the heat trick. Thanks for the replies to such a dumb problem.
