Banks sidewinder turbo considerations doesn’t fit very well
Skrilex
Banned
355
Portland Oregon
Pulling blown engine out of my hmmwv and before removal decided to play with fitting the banks turbo kit I have here for 6.2. It has a cast manifold that places turbo forward by the air filter. It would fit but it would require cutting into passenger footwell. So, my desires to do this install were suddenly shunted in a different direction of hacking the factory tube manifolds and making them feed the turbo in a different location, but overall it turned me off to the idea of a turbo on the 6.2 and may have settled the engine debate for me in the long run. I think I will still install the 6.2 so I can drive it, but I’ll pass on the turbo for now.
Just thought I would echo this finding since I thought I had read that this would work, but maybe that person hacked into their cab and I’m not willing to do that for this little gain. If I’m gonn do major body mods it better be for a good reason.
if anyone has any information to share about this I’d appreciate it.
Wire Fox
162
Indianapolis, Indiana
We require the van-style top-mounted turbo, the body should be lifted I think 1", the doghouse engine cover must be replaced with the turbo design for clearance, and you need to trim the tunnel floor to match the shape of the new doghouse.
The side-mounted turbos are known trouble unless you love custom work and cutting. You've independently found that out for yourself!
Sent from my SM-G530T using Tapatalk
Skrilex
Banned
355
Portland Oregon
It looks like there was offered two different manifolds for the 6.2 banks kits. One put the crossover in back, one puts it up front somehow. That’s the one I have, but I’m curious if the other one has been implemented. I could also just custom weld a manifold but I don’t know if it’s worth the effort.
Milcommoguy
2,428
Rosamond, CA
Just installed new Banks Sidewinder in CUCV. Turbo mounts front right side. Left side exhaust reroutes to front of engine. Couples up to lower front right side below turbo. Do to the way the engine is wack to the right in the hummve frame, turbo out exhaust is not going to work... not with out a lot of rethinking, my two cent worth.
